my coil-near-plug setup
krisj144
75
Dec 29, 2002
bolingbrook, Illinois
I though this was rather nifty when I did it. It's pretty simple actually, just required lengthening the harness a little bit and shortening the ignition wires to fit right. The mounts are just 2 8" strips of 1" x 1/8" aluminum. The FRH manifold required moving the coils someplace else and I've experimented with few other spots, but I like this one the best.
How did you shorten the plug wires?
I have a Magnus and have my coils on the firewall and I had to buy 2 sets of wires. So just got Taylor 8mm. Would like to go to a setup like yours if I could shorten a set of Magnecore 10mmm
I just kind of pried them apart at the end where they meet the coils using a set of needlenose pliers. Worked well.
greathuskie said:
sure it isnt going to melt sitting on the valve cover?
the stock coils on my evo don't melt.
Plus, I've been driving like this for a couple weeks now and have had zero problems. Those coils are made to put up with a fair amount of heat.
What would be the main advantages of doing this and leaving them stock as opposed to a real coil on plug setup? Could you really tell a difference in anything between stock and what you did?
real COP setups are very expensive. I'm cheap so I did the best I could. It wasn't really intended as a performance enhancement, just a better place to mount the coils to keep things clean. Naturally, the car feels exactly the same with the coils in the new location.
