SFRacingGST
- 235
- 0
- May 4, 2004
Warren,
Rhode_Island
i just hope that i do not have problems with a misfire again, i do not have an upgraded ignition. I was wondering how i would check my base timing with a COP?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks for the info, I thought that was right...Allows it. If you're using stock ignition it still has the same triggering system, so it's still "wasted" spark (although I hear that helps clean up the exhaust somewhat, which if true I wouldn't call that wasted at all). It also shortens the distance from the coil to the plug to esentially 0, so "no" resistance, and nothing to pull out (or wrap with electrical tape like the former owner of my talon felt was necissary). In my eyes it's also beneficial that you can get to all your spark equipment out in the open, it was a b*#$h pulling it off the first time.
Misfire conditions might be caused by the change of resistance. The stock system uses 2 coils, each coil fires 2 plugs at the same time, but only one spark is in a cylinder on the compression stroke, the other is on exhaust stroke -hence the term "wasted" spark. Now when you have the same signal going to 2 separate coils to fire individual cylinders instead of 1 coil to fire both of them, you will have a different impedence. The voltage is the same, but the current going to the 2 coils may not be enough to supply both coils with enough energy to light off a mix under some conditions, causing your misfire.i just hope that i do not have problems with a misfire again, i do not have an upgraded ignition. I was wondering how i would check my base timing with a COP?
