my battery keeps dying
awdtalon21
152
Mar 4, 2007
St. Charles, Illinois
i have a 91 talon and if leave the battery hooked up the battery will be dead in a day, if i disconnect the postive termal it will be fine. my question is there a way to see what is draining the battery? none of the the lights are on in the car.
i had that same problem twice before, the first time it was my ground wire coming off my battery and the second time my alternator was shot
Saw your other Post - you've got the Headlight relay hot all the time - I just deleted the HI - LO Switch in the column & mounted a Toggle Switch in the Steering Column Cover.
Here are two links that I plan on using to find my problem, Good luck and keep us updated on the issue...:thumb:
http://www.dsmtuners.com/forums/showthread.php?t=170037&highlight=battery+drain
http://www.dsmtuners.com/forums/showthread.php?t=179481&highlight=battery+drain
1) get alternator tested
2) if alternator is bad get it replaced and make sure you don't have an exhaust leak at the downpipe that is blowing hot exhaust gas on the alternator
3) check ecu caps
hope that helps.
