My 91 talon has trouble starting in the morning?
aroc636
Apr 27, 2005
ofallon, Missouri
My 91 Talon has trouble starting in the morning, It turns over good and it gets spark, and Im pretty sure it gets fuel but what else could it be.
Could just be the temp changing for winter. Try a tune up and check the emissions system for leaks.
Mike
Good idea and I will go one step further. If it's only in the morning you may want to scan your PCM for codes and see if the ect electronic coolant temperature sensor is within proper parameters. If it reads warm when the engine is cold it will cause the pcm to think the car is warm and it will modulate the injectors less thus causing leaner than normal conditions.
Let us know. Good Luck
