My 500hp project need recommendations
chris_taylor123
78
Aug 25, 2010
Sullivan, Missouri
This is my 500hp dd project.. 5 speed 97 eclipse awd.
if I dont get the full 500 its fine but 450 or 475 would make me happy..
Parts List..
Transmission: Jacks Transmissions LLC — 'Stage 5.1' AWD Premium 5.1 rebuild from jacks
Clutch: SPEC Clutches & Flywheels: Auto Parts, Domestic, Import, Truck, Racing, Drifting :: Results By Car One of the 3+ stages or 4 or 5.. not sure where to go quite yet
Turbo: Forced Performance Turbochargers: DSM FP3065 Ball Bearing Turbocharger Fp3065
Injectors: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Precision 780cc Ball-Style Injectors : Mitsubishi Eclipse 90-99 Turbo (Injectors 780cc will go bigger if thats your recommendation I though I would have to anyway.. I was just taking advice from someone else..)
Valves: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Brian Crower not sure which valves to go with yet..
Rods + Pistons: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Eagle Rods + Wiseco Piston Combo: Mitsubishi Eclipse .40 over
Dual valve springs: Dual Valve Spring Set - DSM 4G63
Bearings: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Clevite 77 Tri-Metal Main Bearing Set: Mitsubishi Eclipse 6-Bolt
Fuel pump:Forced Performance Turbochargers: Forced Performance 255lph Fuel Pump (Will this work?)
Doing a 6 bolt swap into the car.. with a 2g head. If i need to upgrade something to reach my goal please relay me some info :)
Tein coilovers
Still looking into:
Full 3" exhaust
Arp head Studs
Stainless Steel clutch lines
New Brake Lines
Drilled and slotted brakes
Ported exhaust manifold
Wastegate
Cams
Nice Loud blow off valve
Fuel Pressure Regulator
Have eprom ordering chip for it soon
Planned on using stock 2g mas but will use something else if needed.
Wanting to know if stock transfer case will work? or need rebuilt.. as well as rear differential.. etc.. anything needed done to make 500 I need to know about.
I was told not to use and aftermarket intake manifold because its not worth the money.. just what I was told..
If theres anything you guys recommend adding or changing??? Any help is much appreciated thanks for your time!!! :D
Look at a Borg Warner s259 for your goals. They have shown to spool as quick as a BB and they are around $200 to rebuild instead of spending $400-$600 for the whole center section. Most people go. 20 over to clean up the cylinders but have your block checked. If your bores are good and have cross hatching go with standard size pistons and save some cash.
On a side note stay away from Brian Crower.
Im in the same boa with the e-85 situation. Same goals as well. I purchased the manleys with ti retainers and my block is also .20 over....I just plan on using 93 octane with meth injection. It seems thats what a lot of people do when their in our boat
a lot of hy35 & he341 holset come with 9cm^2 turbine (good spool up) both these turbos are very afordable and are capable of 500hp
