- Thread starter
- #26
jwcardy
- 118
- 0
- Aug 15, 2007
North Platte,
Nebraska
hey, nice progress, I was wondering why you used so much glaze or bondo. are those really big dings? Im doing body work now, Im hoping Im doing it right. also, I took my dash out are you planning to put that back in?
It does look like a lot of filler but that rear quarter had a pretty good size dent in it. We had to use the weld tab gun in several differnt spots to pull the dent out. Doing so caused the rest of the panel towards the door to get weak, it was really easy to push in. If you have the interior panels off in that area you can see that it is hard to get your hand back there with a dolly to hammer out and strengthen the panel so we feathered the filler out on the panel to make the soft spot a little stronger. Other than that spot, the filler is only use to make the surface smooth after the dents and dings have been pulled
yes, the dash is going back in, i just pulled it to remove the heater cooler, blower, sound deadener and to relocate the under hood fuse box.
-wes
