Must have tool
Gamble97
2,642
63
Jan 3, 2006
small town, Illinois
I went to a wood working show and they had a demo of this tool. I must say that I'm not easily impressed but this blew my mind
Bad Dog Biter Kit
It's a nibble that attaches to your drill. The best part was he cut wood, aluminum, steel, stainless and the edge was pretty damn smooth. I was rubbing my finger on the edge trying to catch a nick or imperfection and nothing. The mount holds your drill to act like a table saw, or other types. I literally almost bought one right there, not sure why I didn't. Kind of mad that I did not.
Cut everything from really then aluminum to 14g electrical box covers. He even had a stainless steel kitchen sink there that he cut up with this thing.
Here is a video
Bad Dog Biter shears sheet metal - YouTube
Looks cool, but it sucks that it requires the use of both hands. Price seems salty too. Most air tool companies make that same type of nibbler. I just used one 2 weeks ago to cut some sheets of steel for a buddy's metal roof. The only downside is that they make a nasty mess of fingernail shaped clippings and they go everywhere.
Harbor Freight even has the air powered ones: 16 Gauge Air Nibbler
It leaves cleaner cuts than a nibbler and you don't need 2 hands if you have the mount.
It's expensive but there are also knock off versions made in china for $70. It also has 3 patents.
The one that I used (similar to the HF one) left very clean cuts. I was very impressed. I could run my finger across the edge of a cut, and it was very smooth. The cutting portion of all of them in this style look identical.
I currently own a set of electric shears and an electric nibbler, and I like this style better than both of mine. So, I might be adding an air powered nibbler to my tool collection sometime in the near fiuture.
I've never used an air nibbler. How much air do they really use? I only have a 12gallon air compressor.
I'm really not sure about that. The compressor we were using was a 30-gal (not sure of the flow rate), but it was turned off and we were just running on the air in the tank. I would assume it's comsumption is low. I'd guess that most cuts take 3-15 seconds to complete, and almost any air compressor could keep up with that.
