MTX Thunder 240 AMP
SilverEclipse96
Banned Member
112
Jul 17, 2004
chi, Illinois
after connecting all the wires to the amp it does not function. the power led does not light on.
Check your ground, and your remote wire! If one of thses is not properly secured or hooked up, your amp will not get power!
Good luck.
Jon
Check the ground. Make sure you grounded to something on the chasis that is metal, and you sanded the paint down to shiny silver.
Check your remote wire, usually blue, and make sure the wire is connected to the right wire from your headunit.
Check your power wire, make sure it is fused shorter than 18" from the battery. Check the fuse too.
Make sure your headunit is on, your amp will not go on unless there is sound playing.
If all that fails, the amp is blown.
If its new, return it, if its used, you got jipped.
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
  • For sale 420A OEM 2G DSM 420a Fuel Injector Wire Harness
    $15 + shipping/fees PayPal, Zelle, Venmo, Apple pay
    • Stizzydrew
