MSD Stutterbox on an Automatic
Its in the vfaq. located here www.vfaq.com
The install for a 91-94 model is located Herehttp://www.prostreetonline.com/pso/pages/howto/dsm1gdis2.asp
It should be the same as a 5 speed install with the exception of the stutter box / 2 step.
I have my 2 step hooked up to my E-brake, and so far so good.
Instuctions from MSD are here http://www.msdignition.com/pdf/dis2_dis4.pdf
Instructions for the tach adapter are here http://www.msdignition.com/pdf/8912_dis_adapter.pdf Yes you need this, part number 8912.
If these links dont work you can always type in msdignition.com
This will soon turn into a "You dont need no MSD" war, but before that happens Id like to say.......the 2 step kicks arse! :thumb:
Besides that.......I think I deserve to say.........http://www.dsmtuners.com/forums/search.php? not as rude, but still gets the point across...
Two steps can be worth it......Not common though, but what other choice do we have with no trans brakes.
Mike
