MR O2 Housing, 4 bolts or 3 bolts and stud
streetdsmpwr
322
3
Oct 13, 2009
Canton, Michigan
I am getting a Megan Racing O2 housing to put on my Evo III 16G and I was about to order new bolts from the O2 housing to the turbine housing and I'm wondering if I can just get 4 bolts or do I have to get one stud because one of the bolts won't be able to fit?
How much cheaper. . . really :)
Besides, its MUCH easier to get an o2 housing on and get that last fastener tucked under the wastegate dump/recirc if its jsut a nut instead of a bolt. I don't feel there's enough thread to go into the turbine housing with a bolt length that can be fenagled into there. I've had gasket problems with that method. I suppose I could have told myself, ":ohdamn: Matt, you should have less backpressure to keep that from happening any how." :)
It's about $8 more for the OEM stud and nut, and I know thats not a lot of money but I'm trying to save money on this build everywhere I can. I guess I could reuse the old nut on the car now.
:). . . Cut your costs where you won't regret them later when trying to get the sucker on while the turbo is on the car. That's the benefit of the stud. Much easier install. It also helps hang you o2 housing and downpipe on while you bolt everything together.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
