2G MPI Relay Clicking/ECU Resetting
2gNickTSi
Nov 5, 2012
Salem, Oregon
My MPI relay is clicking frequently. Just put a new chassis harness in btw. I would replace the relay but I dont think thats the problem because my CEL is gone everytime I start the car until the relay begins clicking again. Im thinking ground/short but I dont even know where to begin.
Never had one click usually like a surge / buzz with no actually cranking.
So def sounds like a ground / short, good luck!
The only times (in 16+ years of owning DSM's) that my MPI ever clicked on + off like what you're saying is when the ECU had leaking/blown caps -or- a couple other times did that with just a bad battery connection.
In fact 2 different times it completely surprised me when even though battery connections were tight and looked clean that by cleaning them solved the problem and I would have sworn it had to be the ECU.
So I'd thoroughly clean those + check voltage and THEN if still no good pull ECU + open to check caps for signs of leakage and burnt smell. After that maybe buy a cheap used MPI relay to swap out. Personally I keep a spare ECU + MPI relay just for that type of problem.
i have a 1g and it was doing the same thing i disconnected the relay and cleaned the terminals and hooked it back up havent had a problem since. try that and make sure the wires are good and the connector isnt loose
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
