MPI fuse on 2g?!
amballer82822
361
4
Jun 4, 2010
Pittsburgh, Pennsylvania
Just want to run a compression test, cannot find the MPI fuse. My cars a 98 GSX a 2g so its different then the 1g fuse box on the battery. I cant find this damn thing anywhere anyone know where it is?:D Also people are saying this doesn;t have a MPI fuse, if so what do i do?
It's the "Engine" fuse on a 2G, but the service manual suggests unplugging the crank position sensor which will cut both spark and fuel. This will cause a check engine light so the ECU will need to be reset afterwards by disconnecting the negative battery cable for 10+ seconds. If you have the OE stereo, make sure you have the security code to unlock it afterwards.
Make sure the engine is at normal operating temperature, all spark plugs are removed, and the throttle is held wide open during the test.
Like Brian said, I've always just removed the blue 20A "ENGINE" fuse located in the top row of the engine bay fuse box. I've never had any problems doing it this way.
