mounts needed for a 6-bolt in a 2g
96gs-t man
48
Feb 8, 2008
Milwaukee, Wisconsin
I am looking at buying a 95 tsi awd and it has a 6-bolt in it. The guy said it needs a new mount on the upper driver's side. Do I need to put a 1g mount on or a 2g mount?
2g mount. You reuse all 2g mounts in a six bolt swap. If you dont have the part of the mount that connects to the block you might have to cut a small section out so it clears the water pump. You should fill the mounts with urathane if u have the time. The directions for cutting the mount can be be found on Magnus Motorsports
