SanTa_
- 224
- 0
- Jan 25, 2007
Methuen,
Massachusetts
This is for a buddy of mine...
"ong story short I got the car all put together today after 10 months an it will crank over but not run, I check for fuel issues an spark an both are working fine. I have the maft set up correct as well as link so this leaves me to think its something to do with the cas, I removed the cas checked to see if it was put in correctly an it was so I borrowed a buddys black top cas an still same issue then that made me think to check the cas for power goin to it an I didnt get a power reading from it, So douse this mean its a problem with the ecu or bad fuse ext ext? when im cranken the motor it acts like the plug wires are backwards.
any help would do
Brandon"
"well its still a 7bolt but I did the 1g cas/cam sensor mod so that would make me need to change the firen order like I did, but I've worked on dsm's that would do the same issue like im haven do to with a bad/ put in wrong cam/cas sensor so this leaves me checken to see why that sensor is not getting power."
any help would do
Brandon"
