Kingarex
- 95
- 0
- Jul 3, 2012
Cheney,
Washington
So I got my new engine back and dropped quickly Its been problem after problem. Had a bunch of sensors and relays blow, o-rings leaked, my new oil cooler gave me trouble... But ive finally gotten it close. It now sputters when starting and will sometimes start and then immediately die. Ihave checked the codes with a obd2 code reader and it's oddly saying that it's a p0340 code (crank angle sensor) which my engine doesn't even have. (95 7-bolt).
I have 3 harness plugs that have no homes that I can find. I ran the wire colors in against a diagram and the orange plug should be a cam sensor (again there was never a sensor on my head before) I don't know the other 2 but I'm guessing one is AC related and the other one(not pictured) might be a knock sensor.
I got it to run once and then shut it quickly off because of a leak.
Any ideas?
Timing was verified.
It has fuel pressure,
New plugs, wires, coil and relays, and everything else is hooked up.
Any ideas?
I'm sure I have a vacuum leak or two. But
Any ideas?
Any ideas?
