Motor Mounts Are Destroyed! I NEED HELP.
GstAllDay
52
Sep 5, 2011
Oakdale, New York
I just found out today that I have these really busted up motor mounts(ALL OF THEM), they are on their last leg. My motor has slid forward and is now rubbing against my fan.:|
There is an excessive amount of motor movement. Im just very worried that I'm going to run into a lot of problems if i dont replace them asap. I have looked online for some mounts but I feel im going to end up with some half a** mounts that are going to break.
So i wanted to ask the pros on which performance mounts I should get. I want some that restrains engine bounce in the engine bay because i have little space in there to begin with.
Please suggest some motor mounts i should buy, nothing too crazy but something Im looking for.:hmm:
I just think that the inserts need to be replaced but Im just going to be on the safe side and replace the whole mount.
*how much would this all cost to be installed?
Any help or advice is much appreciated.
Thanks,
Kevin.
Here are some pictures:
The whole mount get inserts and be done with it , labor for what, all the mounts pita, not cheap, engine out easiest. Check vendors, extreme psi, stm, look at our vendors and pick some that should be it, as for mounts not much to pick from.
I already looked at those sights and they have nothing for 2g's
Bolts use oem ones from dealer and call it done, i got some grade 8 ones from lowes no problems used them for years. Or oem and call it done.
