Motor Mount Suggestions
LxiMax
263
Mar 29, 2011
Uniontown, Pennsylvania
So all four of my motor mounts are shot and the car vibrates more then my previous car that had prothane side mounts and solid delrin front and rear mounts. :rocks: So my question is mainly this... I don't want nearly as much vibration as current or as with my previous car. Will it be acceptable for side prothane mounts and front and rear OEM rubber mounts? This is an 1995 Auto GST by the way.
So like your on the right track to me. If its stock anyways. Energy Suspensions side mounts with front and rear own stock roll stops sounds good. Good Luck.
If you don't want the extra vibration.
Get OEM mounts.
If you want performance motor mounts besides the inserts.
You can look into the Avid racing mounts.
Avid Racing Motor Mounts EAGLE TALON TSI 1990 - 1994 2.0 AC.MM.023
I have the Avid mounts and love them
Personally I don't understand the whole too much vibration thing, never bothered me any.
edit:I just re read and yes you can run 2 OEM mounts and 2 pro-thane mounts no problem.
