Motor keeps dyin/idling abnormally
infamousmarcus
118
May 18, 2004
Juneau, Alaska
well I tried to swap out my stock injectors and put on ev08 injectors...well i realized that one of the evo injectors is missin an o ring, so i put back the stock ones, during the process i must've done something to cause my motor to keep dying on me when i start it and idle abnormally when i try and drive it...well all i did was disconnect the fuel rail from the head, and also the lil bracket that holds the injector plugs, and unplugged to plugs to the right of the rail. I reinstalled everything where it was, back in the same way. What could the problem be?? in detail, i'll turn on the car, it'll jump to 2000 then drop to bout 1000 and be there for bout 5 seconds then jus start dyin down, and when i try to keep it runnin and then drive it, its okay drivin after a lil bit of movin, and then it'll be fine till i pull to a stop and have it at idle...
