2G Motor has been sitting for years, would this classify as normal?
Red 97 GSX
4
Jul 19, 2005
Mt. Prospect, Illinois
Hello all,
My car has been sitting for years and im in the process of getting her ready to start. I turned the motor by hand, with the spark plugs out. Would you consider this just a little rust on the parts for sitting a while or should I be more concerned?? I'd like to fire her up in a week or two as parts come in
Thanks for the help.
This is my own experience
My car sat for 8 yrs undisturbed, I did the same thing you did, but I also added oil to the bores and spent a lot of time rotating with the wrench, and then I cranked her over with the bores open a good couple of times to make sure I built up plenty of oil pressure.
I didn’t want to use a drill on the oil pump.
I flushed the oil and added new oil along during this process, the engine is happy and strong đź’Ş.
This is recent
You should have liberally sprayed WD40 (or some penetrating lubricant of your choice) into the cylinder bores for a few days before turning it over. Turning it is a problem if it had been sitting for awhile. You may have damaged the rings. Only one way to find out.
Sorry, I forgot to mention I added fogging oil about 30 minutes before I rotated the engine. I guess here goes nothing
This is recent
OK thank you. Going to swap out the oil and filter when I get the rest of the parts replaced before I try to start her up. Taking care of the fuel stuff and injectors before I fire her up.
