more boost??
chehsgsx
141
May 15, 2007
monroe, New Jersey
ok this may be a stupid question but over the winter i was running rite around 15 psi of boost. now im running 18 19 somewhere in that range but never above 19. i checked the hoses going to the wastgate and there fine the selinoid is still connected too. everything seems to be fine so why more boost?
possibly a leak or a pin hole in the vacuum lines going to either the solenoid or wastegate can cause that. Had a similar issue like that.
Boost leak would not let him spike to 19psi,
Most likely its your wastegate,
Try connecting a compressor set at 15psi to the wastegate nipple and see if the wg opens,
If it doesnt open then your wastegate is going out
A boost leak test will show if there is a leak in the line going to the wastegate. If there is this will create more boost.
Hook a presure pump up to your wastegate actuator and see how much pressure it takes for it to start to move.
