Mo Problems
4Motion4g63
257
Feb 27, 2005
Lawton, Oklahoma
Well I finished installing my Fuel Upgrades and Went ahead and started the car today!
First thing My Brand New, Only been on my Car For 3 moths, Fuel AN- 90 Fitting at the fuel rail is leaking at the collar around the swivel WTF. I double checked to make sure it was tight at the collar bolt on the braded line and it striped the threads....OMG now it leaks at the collar and the Stripped threads.......Damit And I was SO looking forward to STOMPING some Mustang ass! at 21lbs of boost this weekend..:cool:
I guess I have a Defective AN fitting since its always lost Fuel Pressure rather quickly and I just NOW found where it was going...
Can 550cc Injectors, Walbro 255hp, run off a STOCK fuel pressure Regulator? Just till I get my stuff back from ExtremePsi.com...
Well it turns out that Extreme PSI will do nothing for me and probably wont do anything for anyone else if a Issue comes up.....:toobad: they wouldnt even LOOK at the fitting before shooting me a rejection and even told me they do NOT need my MONEY or me as a customer! :notgood::notgood: The parts were cheap but also LOW quality and thats there IDEA of customer service I hope NOBODY ever does anything with these fools...
I ran for awhile off the 255 + stock regulator. It was night and day when I finally bought the regulator. No more backfiring and stalling. it was amazing.
Yea, you can. You can also run a n/t regulator. I had more success with that then the stock regulator. Runs a higher base pressure. I think its 43 psi, dont quote me on that though. If you do run the stock regulator, and your 255 is rewired, I'd hook up the stock wiring to reduce the voltage at the pump a bit. It will help with overrun because the 255 wont run at it's full potential.
that is kind of poor customer service
but it supprises me i have delt with them on numerous ocasions buying parts and i never had an issue. i was a huge fan of them they were my top company in my profile. i cant say much because i dont have all the facts but i tend to agree i dont know if i will shop there again.
