greekgodchaos
- 565
- 213
- Jul 4, 2007
Vancouver,
Washington
Ok so I bought a Palm m505 with MMCD preloaded on it, but I found out shortly after I bought it that I needed a cable to connect to my OBD1 port, I was in luck because I still had my EvoScan ODB1 to USB cable, however I found out that I also needed a Serial to USB Adapter so I bought a Keyspan one, then found out I needed a USB A Male connector to a USB B Female port adapter so I could hook everything together. Hooked it all up, and it doesn't log. Am I missing something here? Can I not use my perfectly good cable with the palm? Or do I really have to go and do all this: http://www.dsmtuners.com/forums/art...03316-how-set-up-mmcd-make-logging-cable.html Any help would be greatly appreciated. Thanks!
