Injector disable MMCD 1.8g question!
chef
46
Sep 2, 2005
Norway, Europe
When I disable injector 1, 2 and 3 one by one, the engine almost dies... But when I disables the 4th injector nothing happens to the engine at idle. Idle is still at 750 with this injector off.
Is this normal??
When I take the harness off at injector 4, nothing happens. But if I drive the car with this off, the engine drives poorly.
Stock eclipse gsx 90
Stian :dsm:
Is this normal??
Stian :dsm:
NO
If you are doing what you say you are and nothing happens when you get to #4 then you have a plug that is no good or a fuel inj that is plugged or the ecu is not triggering that inj.
Have you done a compresion test ,what do the plugs look like
Yeah, my plug to that injector was bad. If I touches it a little, the engine idles better! Thank you for your help!
Stian :dsm:
