mixing oils
What are you doing it for? Future reference? While I can't give you a 100% fact, a lot of people say not to even mix oils of the same viscosity and weight (possible additive interaction, which causes oil foaming)... others say it's not a big deal in small quantities. I've done this when doing a compression wet test. Though, personally, I wouldn't mix different weights.
But hell, if I'm stranded on the side of the road and need some oil, I'd dump whatever I can in there to get home.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
