mivec
LOL cause the bottom end of my motor is gone nd i need my car to be faster then my friends cars because they all have supras nd hondas unless theres a better way that u kno enlighten me
Start with proper English and work your way up.
Why are you talking about a head upgrade when you start the thread then say you want to have a stronger/better bottem end for a blown short block????
Where is there ever a honda block that is stronger than the 4g63. . . 7bolt or 6 bolt?
But I WILL help you with your street racing goal. . .A better way. . . Swap in the 6 bolt 4g63, put a big enough turbo on it to net 550whp, PLUS supporting mods. Push it to the edge and weld your center diff. Wala, more traction and the same horsepower to weight ratio as all the above. What supra has traction without thousands in suspension? What handa has power without thousands in block work?
