mivec
4G63-T04
Apr 1, 2008
Redding, California
So i've only heard about this being done, never actually seen it. I want to put a MIVEC in my 4G63-T is this possible? and if so, is it worth it?
If you had a 4G63 from an EVO 9 with the ECU then yes :D of course this brings up the question of whether it's actually worth the $ (it's not) build your 4g63 and if you still think you need MIVEC sell your DSM and buy an EVO :p
Well I'm in the process of a complete rebuild of my DSM, it was a 7 bolt automatic. I went out and pulled a 6 bolt and a manual tranny from a talon TSI. So I'm going to have to replace my ECU anyway because of the engine difference and the fact that it's no longer automatic.
So since I'm spending the money to do all this (I just have the engine block the tranny and transfer case so far) I have to replace everything to convert it from Talon to Eclipse. Would it be worth it to slap on a MIVEC while i'm at it? Or would it be a waste?
:cry: you can't just "slap on" MIVEC... Do you know what MIVEC is btw?
yes i know you cant just slap one one, just an expression.
Yes mitsubishi innovative valve timing electronic control system :p
