Missing upper timing cover (Help Read!)
Status
Not open for further replies.
DanThMan1983
245
Dec 24, 2005
Omaha, Nebraska
Okay I am missing my upper intake timing cover but when I went to look for parts it appears its divided into sections? I just got this car and it came without it so I am unaware of what it looks like. Here is my parts list and a picture of the engine, let me know if I left anything out please...
:dsm:
and there are four prices because these parts were in a table. the fourth price is the cost I will pay. also if your wondering its a 92 eclipse GSX built in Feb. 92.
(PS I noticed when searching for parts there is a pretty big price difference in eclipses built to 4/92 and eclipses after 5/92 whats the big diff?
Mechanical Catalog - 1992 - Mitsubishi - Eclipse
Engine, Camshaft and timing, Front cover, FRONT COVER, Eclipse, w/Turbo, Upper, Outer, To 4/92 - 2.0L $45.92 $34.44 $0.00 $34.44
Engine, Camshaft and timing, Front cover gasket, FRONT COVER GASKET, Eclipse, w/Turbo, Upper, Left Side, To 4/92 - 2.0L $0.85 $0.64 $0.00 $0.64
Engine, Camshaft and timing, Front cover, FRONT COVER, Eclipse, w/Turbo, Upper, Inner, Left Side - 2.0L $18.52 $13.89 $0.00 $13.89
Engine, Camshaft and timing, Front cover, FRONT COVER, Eclipse, w/Turbo, Upper, Inner, Right Side - 2.0L $9.58 $7.19 $0.00 $7.19
Engine, Camshaft and timing, Flange, FLANGE, Eclipse, To 4/92 - 2.0L $5.38 $4.04 $0.00 $4.04
Not sure what this is, do I need it?
Engine, Camshaft and timing, Front cover gasket, FRONT COVER GASKET, Eclipse, w/Turbo, Upper, Right Side, To 4/92 - 2.0L $6.48 $4.86 $0.00 $4.86
I am working alot of hours and I dont have time to go to the junkyard and I dont want to wait until I do have time for this since its kind of critical that I have it. So thanks but junkyard is out of the question im ordering new parts.
whoa I have never seen the top piece divided into 4 sections. To me it just looks like you need the top piece. The big difference between these years is the early date and before has the 6 bolt motor and the later date and after has the 7 bolt motor.
well the top apparently just doesnt come in one big piece. the inner side (side facing the engine) is split in two and the outer side (facing the wheel) is one piece and then the gasket is split up as well. If I am wrong someone who knows please let me know I would like to order these parts tonight before I crash out got to work early tomorrow. Thanks again if you guys are able to help me out.
I would have to say it is this 1
well yeah thats the piece facing the wheel and then there is an inside half facing the engine correct?
I started out with just that piece and I got to looking at the parts list and thought maybe its not all just one piece? Need to know for sure.
Ok, is this what you are talking about?
exactly my friend. in that pictures it looks like one big piece?
It is only one piece. PM me, I may be able to help you out.
DSMjrv said:
who cares u dont need the peice... and it looks better without one....
Just make sure nothing ever fall in there. :sneaky: Yes, it's best that you leave the cover on.
Piranha451 said:
Wait! What about those pretty colored cam gears that are just dying to be seen?!? ;)
Just like venting and most other rice mods, it comes with a price. ;)
Exactly. If something falls in there and takes out the belt, You will be seeing a lot more of the pretty cam gears WTF
Mike
Yeah im not brain dead I know it needs to be covered. And wolf I repeated myself several times because the guys that were responded sounded like they were not 100% sure :) I dont want to order something I dont need.
Does make sense Bro.:thumb:
Mike
Status
