MISSFIRES, too lean or burnt valve.
eclipsetech
Jun 7, 2007
La Palma, California
ok so before i say what its doing i will tell you this. i have already replaced the trottle body, intake manifold w/ gaskest for both, deletted my emissons completely, replaed spark plugs and wires, transister pack and coil pack. none of this fixed it. ( i had that stuff laying around)
so it only missfires when im at WOT, in any gear, it starts if im runing anything over like 12 psi. ( i know i have mad creep too, i have it set a 15.5 and it creeps to 23. i understand some porting is in order) i have know way of tuning for high boost, running stock fuel system, no rewire on the fuel pump ethier. i have not run a log, for i have no way of doing so.
i was woundering if maybe it could be missing ### im running lean. i have also been told that carbon build up on a valve could cause a mis as well.
maybe because my knock sensor is bad, it seems unrelated but thought i would through that out there too.
any help would be nice, ive been having to drive my 240 and im missing my eclipse.
THE MODS ON MY PAGE ARE UP TO DATE OTHER THAN STATED UBOVE.
    • Sdcryan1
