2g_rebel
- 0
- Jan 21, 2026
Seville,
Ohio
1 have a 99 eclipse just rebuilt motor 175 across the board on compression. Timing is on point. I have new coil pack new fuel pressure regulator set at 43 base pressure. 12.1 fmu stock ECU and injectors and fuel pump. Seems like when trying to hold a speed it gets a miss. And back roads it drives fine. Under 60. Runs fine when doing pull just seems a little under power for turbo and I had before rebuild
