99GSX_emily
- 0
- Jun 30, 2009
Chanhassen,
Minnesota
I did some searching in the forums search but I couldn't find the answer i was looking for really. I have misfiring when i hit about 20psi in 1st & 2nd gear, & you can see a puff of white smoke comes out the rear! In 3rd & 4th gear its almost impossible for me to hit anything past 5psi, it feels like I'm stuttering like it wants to hit boost but can't! I checked the coil (14.80ohms on 20K ohms setting), plugs (gapped to .028), wires & they were fine plus I've replaced all of them about 8,000miles ago I would say. Boost leak's I've taken care of but Imma test that again tomorrow when i can get my hand on some air! I DO NOT have a APR which i know would make me run pig rich, but would that cause my issue?
But, back to the white smoke, would a blown head gasket have anything to do with misfiring? I do have some overheating issues but only when I'm using the a/c with boost, but no real signs of a bad gasket. And lastly, CEL is useless, it's has been on since i've bought the car. (code comes up as a bad fuel sensor in the tank & o2 sensor of course)
I'm runnin 99 GSX, big16, FMIC, 255lp hp pump, & I&E. Is there something else I'm missing? Thanks for the input!
) so imma had up to O'Reilly tomorrow & get another one for $3 & hopefully that's my fix!
, i just ordered one & i'll get it later this week. Keep in mind i have a evo iii 16g, the stock wastegate should open at 19psi. And i dunno how i was boosting 24psi but i was!
it's comin out at my air filter/maf & spittin everywhere & smoke is going out the back & into the car it's brutal! I'm so confused
