Resolved Misbehaving ISC
A Sharp
158
14
Nov 18, 2013
Platteville, Wisconsin
Car is a 2g talon running ecmlink and a stock maf.
I'm having difficulties getting the isc motor in range, by setting the BISS. At my target idle of 1k RPMs, the isc position sits at about 53 and refuses to go lower. This is with the car fully warmed up (sits at 216 idling in my driveway). Idle switch and closed loop are working as they should. During the adjustment, I unscrewed the BISS and the idle shot up to 1800 RPMS. Then I waited for the isc to compensate... but nothing happened. The isc position just sat at about 53.
The coils on the isc seem fine (all tested at about 32 ohms). Also, I'm quite sure that the isc is able to move. The position fluctuates normally while driving and warming up, and the engine rpm responds accordingly.
It's almost like the ecu just doesn't care that the idle speed is too high.
Also, I know that the isc position should be about 30 for a 750 rpm idle. Should it be higher for a 1k rpm idle? Maybe that's the problem.
Thanks
So besides not meeting the expectations of the wiki. There's nothing wrong with the car....
Look I've been hated on because i idle perfectly and my isc position is 0.
Regardless of the number of variations of remedies.
I've accepted that actual results, are better than expected values.
Your car will be blown sky-high within seconds if you aren't at 30.
Yeah my idle/isc has been a massive headache for me. I've been trying so hard to get it all dialed it but when I fix one thing another one screws up.
Glad you got it working! The ISC does take a while to get setup correctly and can be a real hassle sometimes but it's worth it in the long run.
With a target idle speed that high, retarding timing in the da table in the cells being used at idle and just above it will really help smooth the idle. The factory timing advances quite a bit above 750rpm and really limits the ecus fine tuning over idle speed.
Not sure if you've already done so but you're also gonna want to raise the coastingFC rpm up a few hundred so it's not trying to fuel cut on you at idle.
I have already dialed back the timing at idle in the DA tables, which helped a lot. I wasn't aware of the coastingFC adjustment, though. Thanks for that!
What kind of idle timing numbers are you suggesting? I just looked at a log and I've got about 10-15*'s at idle
