Junkyard ISC
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
Just got another ISC from the junkyard ### my idles been causing the car to stall. Anything I should do to it before I install it?
Like clean it? And if so with what and how?
Use a multimeter to test 1/2 2/3 3/4 4/5 and 5/6. IIRC it should read between 30-50ohms depending on which ISC you have. If you get a 0 reading on any, it's junk.
I'd link you to Jafro's video but I'm on my phone LOL.
Which pins are which? I've checked a few and theyre reading at 29 ohms.
Got it. You check pins 1/2,2/3,4/5,5/6. They should all read around 30 ohms. So mine appears to be good.
For anyone else with a similar problem
http://m.youtube.com/#/watch?desktop_uri=/watch?v=KibYz21IMA0&v=KibYz21IMA0&gl=US
Yea my idle has been terrible lately. Hopefully this is it.
Taking the tricking thing out is hard, why is there a screw that u really can't reach
Any tips on removing the old one? is it me or is this screw in a position that just doesnt make any sense at all.
It almost seems like Ill have to remove the entire throttle body honestly, which is completely stupid
I know this is kind of late, but I always pull the battery and use an extension with a 8mm/10mm (whichever it is) socket. Comes out pretty easy like that.
