Miragepower 3" 2g catback (ETD?)
so far so good. things to note:
1: you have only 2 muffler section hangers on this setup, not 3 like stock.
2: you have to work the flanged end over the rear main bar in between the trunk(like stock except way way bigger)
3" brackets dont line up perfect but WILL work just fine. put the bracket on first, THEN bolt the sections together. its a must.
4: you WILL break nearly every bolt that holds the rubber mounts to the exhaust. count on getting at least an extra 4 or 5. You CAN keep the cylinder they slide into however. just use a knife and small flatblade to gentlyu pry it off.
5: this seems to completely eliminate stock cat if you use the DP i bought.
6: rear o2 lines up and threads perfect. no problems.
7: it hasnt ran yet but fits perfect. bought a 2.5 to 3" DP so thats the final part. looks like it will line up perfect but ill keep you posted on that. heres the link to the catback:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
ill post link to DP if everything works well with that too. this is my first of many product reviews to come, so bear with me. im not that articulate in text yet. i wish i could just dictate this into a recording LOL but this is alot easier.
