Calan
DSM Wiseman
- 7,250
- 401
- Jan 16, 2007
OKC,
Oklahoma
1. we highly recommend spell check and/or upgrading your english. it reflects on everyone's opinion of who you are.
2. tire wear is a function of how much time the tire spends sliding as opposed to rolling, and proper orientation (alignment) to the road. Also the tire compound. is important; hard ( and silica based) tires last longer but offer little to no grip.
3. going off the road as described is most likely understeer; thus too fast for driver skill; not tire tread, unless it was wet pavement.
4. hitting 3-4 inch obsacle, and subsequent damage(?). I would look for a bent rim, tire bulges, broken spring, or subframe damage.
Using proper capitalization and punctuation while correcting another member's grammar is also a good idea.
I still can't make heads or tails out of what is actually wrong either. But, it sounds like there is some pretty extensive damage from what little I can understand; most likely broken shocks/mounts, broken end links, or maybe a bent control arm.
