Megan Racing AFPR
I have seen a bunch of them work fine. personally I like Aeromotive or FueLab, they just seem more accurate.
I have one on my car right now....the install is pretty easy and straight forward....except you have to drill hole in the adaptor piece that bolts to the Fuel rail because the holes do not match up....you also need to use 2 gaskets because it is not flush and leaks...
When you set the fuel pressure it take a long time for it to rise the first time....i set mine drove around for 20 mins pulled over and it was @ 60psi....once you set it the second time it stay where you set it...I have not had any problems with mine yet....
BUT then again I have only had it for 2 days...I highly recommend Aeuromotive...i had it laying around so0o I thought I would try it...I am having good luck with it and will change to Aueromotive when it fails....
For $30 bucks it is not a bad deal at all:thumb:....but:nono: I still highly recommend something PROVEN
yea its a great deal but i was told its not a raiser (1:1). so it doesnt work wit boosted cars
