md oem parts numbers
suprasalas
75
Aug 10, 2011
Yuma, Arizona
What’s up you guys, I’m tired of trying to look up MD parts numbers for hours and ending up with just wasting time and finding nothing.:banghead: So here’s a list I found so far:
This list is for a 95 Eclipse GST with a F5M31 trans
1 - To 11/3/95 MD334948 $1475.38
2 - Head Gasket MD183808 $68.42
3 - Valve Cover MD316252 $288.17
4 - Valve Cover, Inner Cover MD316138 $31.58
5 - Valve Cover Gasket MD186784 $41.93
6 - Intake Valve MD127840 $31.68
7 - Exhaust Valve MD127841 $24.57
8 - Valve Seals MD307343 $5.90
9 - Valve Springs MD185870 $7.72
10 - Valve Spring Retainers MD121000 $6.77
11 - Valve Keeper MD016483 $1.15
12 - Valve Lifters MD377054 $46.60
13 - Rocker Arms MD375091 $28.55
14 - Exhaust MD193148 $317.83
14 - Intake MD335759 $291.57
15 - Right MD102783 $172.55
16 - Left MN137238 $192.40
17 - Right MD131282 $19.98
18 - Left MD187277 $46.78
19 - Belt MR984778 $32.91
20 - Tensioner MD352473 $55.27
21 - Right Side MD188124 $2.90
21 - Left Side MD188123 $1.38
Center
21 - Right MD188122 $4.58
21 - Left MD188831 $4.07
21 - Bottom MD191502 $2.18
Lower
21 - Right Side MD171345 $3.62
21 - Left Side MD188834 $3.28
22 - Right Side MD187283 $11.70
22 - Left Side MD127142 $25.13
22 - Outer MD198031 $66.53
Lower
22 - Inner MD199941 $9.48
22 - Outer MD332865 $62.47
Center
22 – Outer
23 - Without Convertible MD302898 $33.93
23 - Exhaust MD170799 $33.33
24 - Timing Belt MD326059 $85.03
25 - To 8/2/95 MD308587 $108.37
26 - Tensioner Pulley MD182537 $41.20
27 - Piston Ring Set MD313405 $202.92
28 - Piston MD307820 $75.77
29 - Connecting Rod MD193027 $130.33
30 - Bearings MD195939 $21.13
31 - #1, 2, 4 & 5 Bearings MD195916 $30.93
32 - Crankshaft MD346024 $851.43
33 - Rear Main Seal MD359158 $26.17
34 - Rear Main Seal Retainer MD172170 $23.25
35 - Vibration Damper MD377604 $173.73
36 - Oil Pan MD332043 $246.27
37 - Oil Pump MD327450 $257.67
38 - Oil Pump, Case Gasket 1064A040 $15.23
39 - Oil Pump, Oil Seal MD741818 $9.60
40 - Front Crank Seal MD343563 $20.38
41 - Drive Gear MD174581 $72.23
42 - Driven Gear MD174582 $36.72
43 - Oil Pick-Up MD181210 $27.08
1 - Boot MD718557 $6.33
2 - Seal MD747660 $4.67
3 - Bearing MD712913 $8.17
4 - Plug MD701850 $3.38
5 - Gasket MF660036 $1.67
6 - Mounting Bracket MD744671 $64.00
7 - Bolt MF241309 $2.52
8 - Guide MD741725 $6.00
9 - Cover MD720370 $4.55
10 - Pin MF472405 $1.50
11 - Case Assembly MD746106 $263.03
12 - Back-Up Switch MD730979 $22.72
13 - Seal MD707184 $11.53
14 - Breather Element MD733296 $4.10
15 - Cover MD742106 $43.53
16 - Cone MD725928 $33.50
17 - Seal MD707184 $11.53
18 - Housing MD745320 $547.05
19 - Guide MD721067 $2.28
20 - Seal MD741818 $9.60
21 - Bearing Retainer MD735925 $9.48
22 - Bracket MD745087 $80.75
23 - Transmission Mount MD742364 $65.68
IF you download caps or Mitsubishi asa than you have every single part number that you could ever need for any Mitsubishi car right at the click of your mouse.
