max boost with NT 1g motor with dsmlink
DJYoshaBYD
771
Dec 27, 2006
Stockton, California
I want to know how much boost I can make with a 1g 6bolt nt motor and all of my old turbo stuff swapped on... I know it has higher compression and different exhaust cam and whatnot... thats cool... but I know that the rods are still hella strong because they are the same out of the turbo 6bolt....
I know that knock is the enemy, but I dont see why I couldnt run 15 psi if I had the octane and the tune to do it via dsmlink.... im trying to make about 300 hp when I am done... I know these motors are quite resilient, but I also know that 9:1 plus too much boost will probably bury a rod in the street.... if I could tune my ignition, then I should be able to run a decent amount of boost... right?
  • Wanted 6 bolt NT water pipe
    • chrisman287
