Max boost for my Setup .
HOTSHOT100
56
Sep 6, 2005
Montreal,
Hi , I have just check the compression of my motor (150PSI all 4 Cylinder)
I am running right now at 20PSI with no knock and my questions is how much I can increase the boost ?
My SETUP :
6 Bolts Engine
Balancer shaft removed ,
Turbo Big 16G Evo 3 GT ,
DSMlink V2 ,
PTE 680cc Injectors ,
Front Mount Intercooler ,
3" Turbo Back Mandrel Bend ,
Evo 3 O2 Housing ,
Greddy Type Rs BOV With Recirculation fitting ,
Intake With K&N ,
Walbro 190LPH + Rewire Kit ,
ARP Head Stud ,
Lifters Revised ,
Magnacor 8.5mm Spark Plug wires
Denjon Tools J Pipe ,
Hallman PRO boost controller ,
Autometer Boost , Air/fuel and EGT ,
Innovative LC-1 Wideband o2 Sensor ,
Every car and setup is different and will react differently to more boost, more timing, etc. Make changes, log everything and keep checking.
EDIT: Also, I see you have DSMLink, which is a wise choice. If you need help depicting the logs and deciding if more boost or more timing or whatever changes you made were beneficial or not, the DSMLink forum has a ton of really intelligent and helpful people that will give you a hand.
I know but do you have any estimate ? I will do the fine tuning after that .
The thing I will do is to keep the stock timing and increase the Boost until I see some knock .
I will keep my A:F ratio around 11.5:1 with my Wideband .
After I see some Knock I will Reduce the boost by 2PSI and start Tuning the Timing setting
This is the Good way to do or Im lost ?
Sorry For my poor english . Thanks
You have the right idea. Keep increasing the boost 1-2 psi at a time until you see some knock, I'm guessing you'll start to see some knock around 23-24 psi. Can you post some datalogs?
