Master Cyl question (clutch)
my_precious
454
Jan 19, 2004
Jackson, Michigan
Does it matter whether I get the Mastercyl for a speed control car or non speed control car? My car HAS speed control, but I am going to get a 1.8L non-speed control throttle cable and put it on...So what should I get?
To my knowledge it should be the same. However, it's easily confirmed. Call your local parts house and see if the part number is the same. That should tell you what you want to know.
Good Luck
Well if its not, should i get the non-speed controll unit since im going to switch to the 1.8L throttle cable? I dont see why it would matter personally since it doesnt have really anything to do with the cable, maybe it bolts up differently with the clutch pedal assembly or soemthing.
