1G Map sensor vacuum options
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Im on a 1g so no manifold spot to just plug it into. I have my afpr and boost gauge t'd on the same line already so dont want another t there. I thought about moving bov vacuum to the P port and using that manifold position.
I know t'ing the map sensor is not the best idea so without making a new port on manifold im running out of options.
Take the manifold off and drill a hole through the mounting bracket bolt hole on the underside. Thread a barb in there or retap it and thread map sensor there.
This is the optimal way to mount your sensor, depending on the sensor. 1g manifold already have a boss for drilling an tapping. If its a GM style, replace the threaded sensor with a barb to NPT fitting, mostly likley 1/8-1/4 to 1/8NPT, and run a vacuum line to the sensor from the manifold
