Map Sensor and clean engine Vacuum Question
blackrosenova40
398
4
Jan 12, 2006
Belle Plaine, Minnesota
Im running a map sensor setup with the Maft Pro. Where do you guys think is the cleanest vacuum source off the manifold?
If you guys cant think of a very clean one im just gonna drill and tap for the sensor.
if I do drill and tap for the sensor where do you guys think would be the best spot?
Clean off a good spot around the vacuum brake booster, or if you can fit it on the right side like most map sensor cars have them located at.
