1G Manual trans problem
Carlos103183
Apr 15, 2020
Rochester, New York
Ok guy I have a problem with my 1g dsm fwd I can’t get it into any gears I replaced the master cylinder and slave I bleed everything and still doing the same thing if anybody had this problem please let me know wats the problem and the solution I can’t wait to drive this 1g
were there symptoms leading up to this? Clutch not disengaging will lock you out of gear. Cause can be broken clutch components or a broken clutch pedal. If pedal feels normal i would suspect the clutch itself. Happened to me twice on two different cars. Disc slipped a spring. Pedal felt normal but clutch would not disengage.
Ok I replace the clutch and master and slve cylinder i bleed the system it goes on gear when it off but when running it dnt
Ok mine pedal is all the way to the end
I don’t know if it supposed to go like that
What is the step height of the flywheel? Did you bench bleed the master cylinder? Do you have the correct slave as there are two different diameters. Is the clutch pedal assembly working properly? Did you look and test it?
Which is the right one I’m new to this
