CDgr97GSX
- 162
- 10
- Feb 11, 2009
Romania,
Europe
Hi guys. I need some advice with my head rebuid. I got from a guy in UK a set of Manley custom intake and exhaust valves. I knew that are 0.5mm oversized and 109.7mm total length but I did not know at that time what's the valve stem diameter, i thought is stock size, so after i got them i start measuring and i figured out the valves stem diameter is bigger then stock. The part number for the valves is 11281 and 11250 and the stem diameter is 6.96 and 7mm, with stock valves being 6.54/6.57mm.
The question now is how can i fix this? The only way i can think about si to machine the guides inner diameter to fit the valves, but i wanted to ask before i do anything. Thanks
