man exh. manifold on an auto
ramfan98
Aug 6, 2004
Rockford, Illinois
I need a new manifold for my auto 1g, but the only one they have is a manual. Can I still use it?
Wow that's super expensive.
You might be able to port the 13g turbo enough to use a manual exhaust mani, someone else will have to chime in here. But I know that the head bolts are the same, it's just that the collector hole is bigger on a manual manifold. So basically you don't want a bigger manifold hole than your turbo inlet, see what I mean?
You can use a manual manifold. The only difference is the outlet going to the turbo is smaller on an auto vs the manual car. I ran a manual mani on my auto with a 13g for a while. If you feel like spending some time to make it right, and maybe gain a couple HP, you can port the turbine inlet on your turbo to match the manual manifold.
Wouldn't this cause excessive back pressure?
I've been reading alot about 13g turbo's and people have said that they really come alive once you port them. Only thing is I'm not sure if you can port them large enough to match a manual manifold. I wouldn't want to run one though w/out porting the turbo also, even if you can't get a gasket match you could get it closer.
13g's are restrictive little buggers, makes a T25 feel like a 20g in comparison. 2g exhaust manifold will work with a little corner grinding to clear the power steering pump. I agree that port matching will help. I still have my Garret "50 trim" modified TD04 turbo. Full boost by 2500 rpms and perfect for daily driving an automatic.
It's a 1g. No cracks. I marked the gasket size of the manual manifold as a reference so those who didn't know can see just how much bigger the manual outlet is than the auto.
yeah, thats definitely the 1g auto. i have one laying around, but its cracked on the underside. Yours looks good though!
Holy hell thats a lot of grinding to do. Get a good carbide bit and have atter.
He has a 13g turbo, so that manifold would fit perfect. It's probably not worth grinding a 1g a/t manifold to match a 6cm or 7cm turbine housing when you can purchase a 2g manifold for <$50
Call me crazy but I've been wanting to get a 1g auto and only do very basic mods, still keeping the sidemount. It'd be a zippy little DD.
With the Roadsurge shiftbox or manumatic mod, the trannies shift nice and quick at 100%pressure and seem to last
I loved my 1g auto gsx. As soon as I get a decent job and get some bills paid off I want to get another one. I say go for it. Autos don't get the respect they desrve.
Thread Revival!
I'm in a situation where I cannot afford to currently replace my 13G but I have a really bad exhaust leak from my exhaust mani, I have a 1G manual mani I got for 5 bucks a few months ago and was wondering if could I run it.
I may be able to slightly port the exhaust side of my turbo, but would I have problems if I don't?
I'd rather not spend the 150 on rockauto for the auto mani w/ gaskets unless I have no other choice.
manual and auto manifolds are the same
No they are not..The part that flows intot the turbo is larger on the manual manifold...You can use the manual manifold, or a 2g manifold..I would also port the in on the turbine housing, just to match it up..But you don't have to..
AK thunder go ahead and put on the manual manifold...
