Major oil leak and engine problem
awdlove89
Nov 9, 2007
hanover park, Illinois
i Have a 92 talon tsi and im havin many problems the car starts and runs but the idle is really messed up and my turbo wont spool and i have a major oil leak...ive checked for boost leaks and im going to replace the spark plugs but my turbo is in good condition i have no clue wuts wrong can a bad spark plug not allow my turbo to spool please help
OK, My crystal ball seems to be an the fritz. Where might the oil be coming from? Top-bottom-left-right- front or back.
With just a wee bit of help some one here should be able to come close to the cause.
Also Welcome
well first things first: find out where the oil leak is coming from and fix it. it could be the drain tube from the turbo. next step is to do a full tune up and then continue from there.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
