Major oil leak
TotalEclipse21
161
May 20, 2008
Conover, North Carolina
I just replaced the head gasket and I am sure I torqued all the bolts down correctly. Whenever I drive it and come to a stop it leaks oil onjust about everything so I cant really tell where it is coming from. Anyways, it gets on timing components, the alternator, and everything else on that side of the engine all the way until the ground. I would just like some suggestions on where to look and what measures I could take to fix this problem. Thank you.
I was thinking it was the valve cover because I didnt do get a new one or put silicone sealant on it, the old one seemed to be in good shape but maybe I was wrong. I'll buy the gasket and silicon sealant tomorrow, it's getting late here. Any other suggestions?
if you look at my old posts i had like a stage 5 oil leak... i found that it was my valve cover... not only was it cracked the orings were done and the valve cover gasket was some cheap rv spray.... try looking at those gaskets and see if they are still good.. i picked up a set of orings and a valve cover gasket set for like $40 from pep boys
The new seals and gaskets fixed the oil leaking problem, but another problem has risen. I will start another thread about it. Thank you everyone!
