turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, I thought that the pedal moving was due to the bushings in the top being worn out and this wasn't a job i wasn't looking forward to it as i've heard removingthe 2g clutch cage was a bi*** of a job.
BUT........... I got the cage out in 15 minutes and ripped it apart inprobably another 2 minutes..then i found this
As you cna see the bushings and pins are ok looking to the eye, and measured out for clearance they were well within acceptable range... that's when i saw..(key dramatic music) the clutch pedal was 1/4 inch away from being a piece of scrap metal laying in the driver floor board
so i knew what to do, this was metal waiting to be worked over, a tree waiting to become a 2 x 4 and so i set out and did this
making it stronger required more metal
and after fitting the little piece and welding it up, i now have this
so now it's fixed, and a litle note... the peda;l broke in the HAZ from the OEM process where the piece for the clutch switch was welded to the pedal assembly
now is wqhen it got fun though, and amazed me and my friend who thankfully was there as my witness Jorge (A.K.A. El Cuervo from here on tuners)
We went for a little ride got her warmed up and with theboost at 25 psi and a clutch that i haven't felt in YEARS (i told him it felt like i just bought a new camry or something becaue this wasn't a DSM clutch
We pulled out onto an empty road, I was maybe coasting at 1/2 a MPH and at half throttle i engaged the 4750 RPM 2 step and let of the clutch fast but not dropin it (probably my best ever launch since going AWD as far as technique) We left the line spinning all four (or at least three of em) and continued with them straight lit up and screaming for a good 60 foot until i let off and swapped to 2nd gear so efforlessly and as flawless of a shift as i could ask for, we chirped the tire a bit but nothing special and again rocketed off.. Now for some of you this is nothing special but the way this car lit up all four tires is more than i've seen in any you tube video or experienced first hand especially in 51* ambient temps on bone dry pavement!!! We were both stoked, screaming ajnd hollaring like little school kids with new toys and shit
it was litterally a whole new experience for the both of us.. And like i said i'm just glad i had him as a wintess or i wouldn't tell the story out of fear of some one calling the BS flag on me, but this is something i NEVER thought the car had in it. I figured the driveline would snap first or something, or maybe bog, but no nitrouse or anything and we straight lit it up like a one wheel wondering 2wd car with a good turbo could, i still canb't believe it, i just fed it clutch as fast as i could and stepped into the throttle maybe 3/4ths the way and then stepped in 100% when i was fully off the clutch and she just performed, especially for being only 25psi and not intending for ahard launch.
well that's my story
888888888**************************** EDIT
well, here a couple hours later i'm still stoked had to go revisit the road and see my marks and relive the thrill of spinning all four on the lanuch and making them bitches howl like a scolded cat for a good 40-60 feet..judging from the marks i know it was at least 40, probably 60 at most to be honest, but i seriousely thought drivelines would break before dishing out anything like that after all the youtube videos i've searched about launching 2g's and such and everyones videos about "spinning all four" you never hear more than a chirp, mine plain wouldn't stop until i shifted.. this is a thrill enough to last me at least a week or so at my adrenaline consumption rate..sorry had to blab i'm still so stoked for myself and my car (i'm proud, and glad to have a damn witness
EDIT # 2 ****************************************************** how many????
Being as hard as this was to diagnose and how long standing it's been with me adjusting around it (i seriousely have more clutch thajn i've had in well over 5-7 years or so, literally i'm 10 turns in from the reliefe valve being closed off and have engagement higher than i want, more throw than i need and can shift without effort and never even get the pedal near the floor for full disengagement, i am just stoked but i wonder how many others have had this happen or are dealing iwth it right now???
this literally could not be seen from the angles you can look from when workingunder the dash, and i'm a pretty thorough mechanic in my opinion. this is i gues something i would say a lot of people chasisng consistant 2g clutch drag should possibly be on the lookout for.. it only took 15 minutes to pull the birdcage for the clutch pedal and there's only one 12mm bolt that's hard to get to but a wobbly shallow 12 socket on 1/4" ratchet makes it a breeze and i think it's well worth a peek. maybe this is that "clicking" a lot of us 2g guys hear coming and going when it pleases (metal creaking) when running high pressure plates.
I just cannot say enough about what this did for my clutch feel and engagement/disengagement, it makes me have a new light on shifting a DSM tranny, and since i normally don't beat on customer's cars (let them do it while i sit shotgun tuning) that goes for friends as well, but this is great shifting compared to anything i've experienced in other peoples DSM's i've been in over the last few years as well.. of course the main other DSM i'm in has a RPS twin and the one aside from that has a 3500 dollar tilton in it and those are like OEM clutches to push (so jealouse of them i was
) but aside form those, i haven't messed with any other really built 2g cars. I've been in a lot odf 1g's in the past that are really built but they have a complete different feeel anyway and their own clutch pedal issues to fix and deal with.. I would say that this adds almost as much excitemetn back into my DSM as the conversion to AWD did
)We pulled out onto an empty road, I was maybe coasting at 1/2 a MPH and at half throttle i engaged the 4750 RPM 2 step and let of the clutch fast but not dropin it (probably my best ever launch since going AWD as far as technique) We left the line spinning all four (or at least three of em) and continued with them straight lit up and screaming for a good 60 foot until i let off and swapped to 2nd gear so efforlessly and as flawless of a shift as i could ask for, we chirped the tire a bit but nothing special and again rocketed off.. Now for some of you this is nothing special but the way this car lit up all four tires is more than i've seen in any you tube video or experienced first hand especially in 51* ambient temps on bone dry pavement!!! We were both stoked, screaming ajnd hollaring like little school kids with new toys and shit
it was litterally a whole new experience for the both of us.. And like i said i'm just glad i had him as a wintess or i wouldn't tell the story out of fear of some one calling the BS flag on me, but this is something i NEVER thought the car had in it. I figured the driveline would snap first or something, or maybe bog, but no nitrouse or anything and we straight lit it up like a one wheel wondering 2wd car with a good turbo could, i still canb't believe it, i just fed it clutch as fast as i could and stepped into the throttle maybe 3/4ths the way and then stepped in 100% when i was fully off the clutch and she just performed, especially for being only 25psi and not intending for ahard launch.well that's my story
)EDIT # 2 ****************************************************** how many????
) but aside form those, i haven't messed with any other really built 2g cars. I've been in a lot odf 1g's in the past that are really built but they have a complete different feeel anyway and their own clutch pedal issues to fix and deal with.. I would say that this adds almost as much excitemetn back into my DSM as the conversion to AWD didAttachments
good thing you found your problem. Now thats make want to check mine if is not broken like that i been having issues with engaging reverse as it makes a loud griding noise.. hummm
