maft set up?
magik95
401
Feb 24, 2008
aurora, Colorado
Ok first I want to apologize for this question because I know its been covered!!
I just want to verify a couple of things.
One is if I have chiped burned for 550s do I set my maft for 550s also?
Second are the settings for that Aux=4 and base set at c?
And the rest set at 0?
Thanks.
Your chip should be already set for the injectors so set the translator to the stock 450 injectors. for a 2g translator version 2.02 the settings will be
aux=4 base=2 . if it's version 1.3 your settings will be different. hope this helps.
Correct. but you may need to tweak a little to get the optimal fuel trim. it's different for every car.
