2G MAFT problem need help fast...
98GSt_4life
201
Dec 11, 2006
Orlando, Florida
i just finished installing my maft in a blowthough setup. i have the settings at AUX:4 BASE:2 everything else 0. when i started the car it stumbled around for a min then got better, but when i checked my logger my timming was at -1 to 0 at idle.(befor i put the maft in it stayed at 5-6)
and now my check engine light came on for code p0100(no air flow signal)
i still havent connected the wight wire for the RPM signal, ### im still not sure were to put it.(i tryed connecting it to pin58 but when i did that the red lite was blinking twice, which weans no maf signal)
The white wire goes to the CAS for your RPM signal. This is what allows you to adjust the settings on the MAFT. Im not sure what CAS you have but my black top CAS it was the smaller black wire on the harness. Just splice the white wire from the translator to there. I had all of my setting's 0'ed out as well though. Ran just how it did before. Now i have them adjusted becuase of a tune. Good luck dude!
i bought the extentions and mounted the maft inside the car. so i tried connecting it to pin 58 on the ecu(a wight wire i think) but i should not have to worry about that sence im not running it in RPM mode right now
hey bro if i got this cas which cable do i conect the white wire to
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
