Maft gen 2 installation issues
TheCykotik1
71
Jan 25, 2007
Fort Wayne, Indiana
Installed my MAFT Gen 2 and it wont power on. It came on the 3rd time i unplugged it then plugged it back in, faintly. I also noticed that when the MAFT is plugged in my SAFC2 will read 23% throttle, then when i unplug it it goes back to 0%. Anyone have any ideas?? I had everything unhooked and put power to the pink wire and grounded the black and it still didnt power on. Ive seen it come on 1 time and it was fading in/out while it was on, then when i started the car it shut off. The car ran like crap and threw a MAF code. Bad Translator? Checked all the connections they are tight. I cant find anywhere where it says where the wires from the GM maf connect to either. I assumed green to be the signal wire, pink to be power, and black to be ground. The green/signal wire i have connected to the MAF input on the translator. Someone correct me if this is incorrect. Any help is appreciated in advance. Thanks :confused:
unfortunately sounds like you have a bad translator. if you hooked it straight to power and it didn't come on then there is definitely something wrong with it as for hooking up the MAF that it correct.
